Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › smeg d/washer. drain pump pulsing on/off.
- This topic has 8 replies, 5 voices, and was last updated 16 years, 4 months ago by
TELL.
November 22, 2009 at 12:35 pm #50332
TELL
Participantsmeg DI612C. S/no. 50207 121810. customer set this dish washer away on wash, told me it shut down near end of prog, and just kept making a sound, pulsing approx every 15 sec’s. got to m/c no f/codes, no lights flashing, or any indication of whats happening.
i reset appliance and started on prog, it went straight into a full drain at start, then just shut down, and drain pump pulsed on and off indefinatley.
no fault codes are displaying, there is no flood in the base, and the flood micro switch etc all ok, heater ok, pcb looks ok, no broken wires?.
appliance just sits there switching drain pump on/off.
any ideas
TELL..November 22, 2009 at 1:03 pm #304463Penguin45
ParticipantRe: smeg d/washer. drain pump pulsing on/off.
PCB corrupted – check mains suppressor and dispenser solenoid as possible culprits.
November 22, 2009 at 7:41 pm #304464eastlmark
ModeratorRe: smeg d/washer. drain pump pulsing on/off.
As Chris states, but good chance this one may be dispenser only, if not quote, and change, both.
November 23, 2009 at 10:28 am #304465TELL
thanks for the replies gents, i take it this appliance puts a pulse out to various components to check they are operational, before it starts, and if not aborts the programme?.
but, would it not come up as a funcional fault with a f/code.
thanks
TELL..November 23, 2009 at 12:01 pm #304466eastlmark
nope, there is no fault code for a faulty dispenser!
November 23, 2009 at 3:00 pm #304467DentedPorsche
Hiya,
I normally disconnect the dispenser and slave on a washing machine inlet valve, try the machine, if it runs, fit a new dispenser.
Just disconnecting it doesn’t work, it requires a resistance.HTH
Brian 🙂November 23, 2009 at 3:32 pm #304468adv
could be board qer fixed one for me
November 23, 2009 at 5:53 pm #304469eastlmark
adv wrote:could be board qer fixed one for me
But still change the dispenser as it will blow the new/repaired board!
November 23, 2009 at 11:08 pm #304470TELL
thanks for the advice, gents. back to call and will check these out.armed with prices for customer,
thanks
TELL.. -
