smeg d/washer dwd1sse,no go?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries smeg d/washer dwd1sse,no go?
  • #38611
    jenson
    hi,havent looked at this job yet,but its a smeg d/washer dwd1sse,which has a digital display which shows fault codes,if you set this 1 on a p5 (one of the programs) and press start in makes a clunking noise,shows minutes for the program then swithes back to p5 and stops,first thought is the door interlock,but havent done much work on these,any ideas would be appreciated,
    #259433
    Re: smeg d/washer dwd1sse,no go?
    Have you looked in the “known error codes” thread towards the top of the forum?
    Mike.
    #259434
    jenson
    i have,but no fault code appears,im looking at it today,il post more info if i cant get over it,cheers
    #259435
    should show a fault code, but the clunking noise could either be a blocked drain pump (as that is powered up straight away) or the alternating valve maybe (usually gives a fault code though).
    #259436
    jenson
    soap dispensor valve was o/c,all good now
