Smeg D612c Last 2 Lights Flashing
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg D612c Last 2 Lights Flashing
  • #51253
    redtigga
    Not sure if anyone can help but……..
    Couple of days ago dishwasher displayed a problem when finished. The last 2 lights flashed as normal but didn’t cancel out when the programme button was pressed. Even when switched off and back on again same thing. Oddly if you switch off, close the door and open again the programme button is operational once more.
    This seems to happen only on the last 2 wash categories i.e. it doesn’t happen on the eco wash.
    Cycle seems to complete and dishes are clean so bottom line should I be concerned or not?
    #307397
    Re: Smeg D612c Last 2 Lights Flashing
    It’s not a “logical” problem, therefore, you’re looking at a logic problem with the pcb. THIS ARTICLE explains the basic problems.
    You need to deal with it as the pcb will eventually corrupt completely – big money.
    redtigga
    Is it economical to resolve or should I consider a replacement?
    #307399
    Substitution is the the only way to find out and the parts are not cheap.
