Smeg DC122W circulating issues
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg DC122W circulating issues
  • #77093
    OLLIE2806
    Ser – 1040710071
    The above dishwasher has a problem with circulating the water, sometimes it circulates ok but other times it tends to circulate but without any real power? Its had a new circ motor and capacitor, I’m A bit baffled.
    Also the salt light stays on all the time, even though the salt pots full?
    Any ideas?
    #400979
    Re: Smeg DC122W circulating issues
    this could be a collapsing pump- heater hose, especially when water is hot part number 758973776, the new one is strengthened with ribs.
    #400980
    OLLIE2806
    Thanks, Ill give that a go, Any ideas why the salt light would continually stay on?
    #400981
    OLLIE2806 wrote:Thanks, Ill give that a go, Any ideas why the salt light would continually stay on?
    aside from the obvious one? 😮 Have to short out the reed swtich to confirm its a dodgy reed I guess, should think un related to fault unless there is a major pcb issue.
    #400982
    OLLIE2806
    ok. Thanks. If so Can you get the reed switch on its own or does it come as part of the salt pot?
