Smeg DEI710e1 Problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DEI710e1 Problem
  • #19572
    geoff123
    My dishwasher has stopped working.
    I got to the end of it’s cycles and I think it finished.
    I then loaded it to do another cycle, went to make the light stop flashing to select the programme for a wash. The light won’t go out and is just flashing on the middle light. No other lights are on.
    I have referred tp the fault codes but this isn’t a fault as far as I can see.
    Have made sure all water has now been taken out.
    Tried putting water in too.
    Also tried resetting but to no avail.
    Help what’s wrong with it?!
    #183697
    geoff123
    Re: Smeg DEI710e1 Problem
    Sorry it’s a DWI 170 E1
    #183698
    geoff123
    doh
    DWI 710 E1
    #183699
    Dave_Conway
    You could try resetting it (type “smeg and reset” in to the search without the quotes to find how) and see what happens.
    If that doesn’t cure it, it’s engineer time to be honest as other component failures can cause havoc with the software on these, the repairs@ link below should provide a contact 🙂
