SMEG DF410S – heating problems& will not stop at end of cycl
Home Forums Public Support Forums Help And Support Dishwasher Help Forum SMEG DF410S – heating problems& will not stop at end of cycl
  • #62389
    tonydee1965
    I set a Program (cycle) to last for 43mins. and as it counts down, when it gets to 0 mins, it then for some reason jumps up to 10 mins and counts down. This is repeated continuously so the machine does not in fact stop.
    When I open the door, the water is doing its thing but the heat is warm but not hot like it used to be
    My dish washer model has 5 program buttons (for 5 different washes).
    What is the reset sequence for this model?
    We rarely use this machine (3 years old and have only used it about 20 times.)
    I have dismantled the bottom of the SMEG Dishwasher & put a multi meter (Resistance) on the terminals of the heater element and it shows approx 30 ohms so I suspect this NOT being the fault plus on some wash cycles the water does slightly warm up. I have inspected the heater (and other parts underneath) and all looks fine – ie no black burn marks on the element or any other component underneath.
    I could not find any reset button for the thermostat (let alone find the thermostat)! Is it integral with the heating element for this SMEG slimline model (45cm) ?
    Next, I took the top part of the control unit off to inspect the PCB and again, this looks fine – ie cannot see any dry joints/blackened area’s of any signs of a problem there.
    I am considering sending the PCB to ‘QER’ repairs who can check it.
    Any further suggestions to what may be the problem before i do this?
    Thanks Tony
    #349903
    tonydee1965
    Re: SMEG DF410S – heating problems& will not stop at end of
    I have re-checked this fault again tonight and in all cycles the heater does not heat at all even though on checking the heating element shows approx 30 ohms.
    Please advise,
    Tony
    #349904
    There has to be a thermostat or thermistor and quite possibly an overheat stat as it sounds as if it could be that failed.
    tonydee1965
    Where would this thermostat be on this SMEG Slimline (45cm wide)model of Appliance.
    I checked in the door panel but it is not within there.
    Please advise.
    Tony
    #349906
    mcdapp
    The Smeg 45cm is like the indesit 45cm.. there is a stat at the rear of the dishwasher .. take of the rear plate and you will see stat its on a thread. check that kind regards Mark
    #349907
    johnsdad
    The thermistor is in the door, clipped next to the dispenser. There is no stat underneath, only a turbidity sensor
