Smeg DF612 SDX dishwasher unlisted fault code ?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg DF612 SDX dishwasher unlisted fault code ?
  • #91843
    snig
    Above dishwasher faults after about 3 minutes, 4th light flashing, 5th light lit. Not listed in fault codes and no obvious faults found, anyone have any ideas or info ?
    #449465
    Re: Smeg DF612 SDX dishwasher unlisted fault code ?
    looks like it may be an early one
    from a post by Penguin45 on known error codes page 3
    Be advised that solenoid failure/ breakdown/poor connections can corrupt the board and cause unlisted faults.
    may be relevant
    snig
    yes, i had seen that but solenoid seems ok, machine fills and starts to wash beforse fault occurs, but thats what makes me think unlisted fault = corrupted board ??
    Anyone have any service info on these ?
    #449467
    if it is an early board as I think it may be we used to get a lot of cap failures but normally it causes the board to crash when the heater kicks in. does it fail round about that point as it will start to heat just after the soap dispenser opens
    snig
    Not sure it runs for that long ,but i would have to check that !
