Had this problem with our Smeg for some months and just stopped using it. Unfortunately my wife wants it fixing now!
There doesn’t appear to be any error codes, the symptoms of the problem are as follows –
– drains on activation as expected
– then nothing, it appears to be heating the water as there’s steam.
– a clunking noise can be heard from the bottom of the machine (sound like the impeller is broken and bits are stuck in there).
I’ve tried to look into this and it appears there could be one of two problems.
1, the impeller has broken and a new pump/impeller is needed.
2, the inlet valve has failed, i sort of doubt this as the waters being heated.
Could anyone offer some advice please?
Thanks in advance
Mark
