SMEG DF612SE
  • #26230
    This machine will not operate the heater or dispenser solenoid and will not throw up an error code for no heat. I assume that this is a logic fault on the computer (816290885), but confirmation would be nice!
    clivejameson
    Re: SMEG DF612SE
    I’ve had one like that before Chris but was obvious when i opened the pcb box…lots of black nastiness 😉
    Mind you, the element was earthing better than a mole 😆
    #209291
    Re: SMEG DF612SE
    No damage to PCB, element checks out……. 🙁
    clivejameson
    Re: SMEG DF612SE
    Common sense says it has to be the board then….
    #209293
    Re: SMEG DF612SE
    Yerssssssssss…….. Ta, Clive.
