SMEG DF612SE DISHWASHER
  • #24648
    DJ-ApPlIaNcEs
    Hi, First post 😀 Question is from a customer who posted this short note through my door regarding her Smeg DF612SE, The problem was …
    “Hi, my dish washer works sometimes others it goes to power up beeps alot then resets, as it goes to start it turns off again no matter what program even power button when it does work it goes through its program no problem it can work 2 or 3 times then it stops again”
    Now looking through the faults you lads are comming up with the soap dispenser door relay, this is what im thinking too as she says “it can work 2 or 3 times then stop again” This to me dose not sound like a pcb fault more like water getting into the relay.
    Dose any one think different or has a thought on this customers discription of the fault. thanks and what a fantastic site 😀
    #202850
    Re: SMEG DF612SE DISHWASHER
    Dispenser solonoid faults not normally intermittent, but worth conecting one up anyway.
    #202851
    DJ-ApPlIaNcEs
    eastlmark…Thank’s for your help. 🙂
    #202852
    PINKY
    I’d check the motorized valve.Can be very intermittent
    Pinky
