DF612WE sn 804180541-0 DW with E6 water pump out malfunction. When you switch on it does its usual long pump out then stops for 5 secs, it does this 3 times then errors out (E6 water pump out malfunction)Any ideas? I am thinking pressure switch or board fault. Customer had replaced the perspex cover on the start button but says was working ok before this? Cheers Kez
Worth checking the fill chamber and transfer hoses for blockages and (obviously) the p/sw for function. Failing that, pcb is all that’s left. Bear in mind these machines propensity for corruption issues caused by the mains suppressor, dispenser solenoid and occasionally the motor capacitor.
