Smeg DF614WE ( D/W)
  • #65257
    rocker
    The visual led that activates the two push buttons had broken
    I tested the pcd (without this part) and it started a cycle so I then ordered the visual led, when I fitted the part..I was unable to change the programe it is stuck on the 1st end light showing..according to the manual both end light should be showing !!! have tried to reset. nothing happens any advice would be helpful. if the pcb had gone it doesn’nt explain why it worked on first call.
    thanks John
    #359845
    Re: Smeg DF614WE ( D/W)
    what is a “visual LED”?
    #359846
    The Control Panel I would think?
    #359847
    Martin wrote:The Control Panel I would think?
    Why, exactly? is there some other meaning to the term LED?
    If he means the levers that control the pcb, there is a mod for this, which comprises of 2 parts, if you dont fit both then the buttons are not operating the switch on the pcb.
    769350131 PCB support
    764730267 levers.
    #359848
    rocker
    yes it is the leaver unit that controls pcb…I have fitted the new unit both parts..and are operating both pcb buttons…but cant reset pcb
    #359849
    is the wash programme still running then when you shut the door and press start?
    need to keep that button down for a good 5 secs with the door shut to reset.
    #359850
    Lawrence
    Smeg DF614WE ( D/W)
    eastlmark wrote:is the wash programme still running then when you shut the door and press start?
    Agree with Mark ,sounds like you need to cancel program ,these things break a the time hence mod kit
    I am here: http://maps.google.com/maps?ll=52.053664,1.122915
    #359851
    rocker
    I have fitted new part, the programe is at the end of cycle (light on) and is dead cant reset!!! and yes the levers are new and working correctly
