Happy New Year all 😀
I have a freestanding Smeg DF614 which had a text book fault, the button frame had broken so fitted the new one with the reinforced plastic bit and all worked perfectly 8) …then when trying to cancel the program, it froze and all i have now is the program light on and nothing else will work 😕
I have tried leaving it unplugged etc but no joy, if anyone has any ideas it will be much appreciated!
are the bits fitted correctly? If it worked before you changed the plastic stuff it would be very bad luck for it to fail, more likely the button frame thingy is permenently depressed, remove it reassemble it and try again.
…if only! was all working fine until i tried to cancel the programme 🙁
all the buttons work okay, have left it unplugged overnight with fingers crossed 😕
