Re: Smeg DFC612s
appleelectrics wrote:that’s what I thought but no water in base, float switch etc all ok
possibly feet not wound down and machine resing on base causing spurious float switch operation. Begs the question why manufacturers always supply stuff with the feet wound so tightly in that you need mole grips to release them. Most dishwashers I pull out these days are resting on their base with he feet hanging uselesly in mid air.
Think this one might have a pressure operated float as well which means an overfill can cause an E1 without actual leakage occuring.
