Smeg DFD6 132X no water in
  • #89814
    mike100
    Water up to inlet valve, thinking of getting new valve but just wondered if there is another fault that could be problem before .
    wash pump motor ok.
    Mike
    #442649
    Re: Smeg DFD6 132X no water in
    just need to see if valve is being fed volts should be the answer. Usual no fill is blocked air break, pull the hose from the valve off the airbreak and stick it in a bowl and see. 766610192 is air break.
