this is a rarely used d/w. 2 or 3 times a year. noticed water supply is off the hot pipe. select any program, and the drain pump comes in on/off, on/off, on/off…no water or damp in bottom tray so not likely to be flood prevention…no water in just on/ff drain pump.
thanks
richardable
They do 3 or 4 back washes before complete fill…seems like an age before the wash pump cuts in. If the drain pumps runs for a minute or so then stops for a about half a minute then repeats it sounds like it simply isn’t taking in water.
Is the hot supply pressure/flowrate sufficient to open the valve?
