SMEG DI6 FABP (0102008741) Dishwasher Problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries SMEG DI6 FABP (0102008741) Dishwasher Problem
  • #84380
    jontymox
    Could someone please help me with a problem on the above dishwasher?
    When a wash programme is selected, the appliance draws water normally, washes for two to four minutes, and then drains again before beeping, and aborting the programme.
    There are no error or beep codes sent, so I wondered if the heater was faulty, but it gives a good Ohms resistance reading.
    I’m wondering if the electronic control module is faulty, or if that would send an error code?
    Kind regards,
    jonty
    #425518
    Re: SMEG DI6 FABP (0102008741) Dishwasher Problem
    unlikely its the heater, surprised no error code flashes…. are you sure there ar no flashing lights?
    check it has stopped filling, should stop after about 30 seconds from when the circ pump is started.
    You say it draws water normally but these should do a drain and fill sequence for a good 3 minutes before filling and washing.
    #425519
    jontymox
    Thanks,
    I’ve brought the dishwasher to my workshop, and run it up again.
    It drains and fills well, and washes for around three minutes, before draining and aborting the cycle.
    When it aborts five beeps are sent, and the two programme lights, (four and five from the left) next to the programme selection button are lit. These two lights incorporate the end of cycle status, number “four” flashes, and number five remains constantly lit.
    The small display doesn’t send any message/error code.
    Can you, or someone decipher the above, which would be a great help!
    jonty
    #425520
    diverter/alternater valve needs changing, part number 819130468
    #425521
    jontymox
    Thank you for the info’… you must have come across this problem before.
    Best wishes,
    jonty
    #425522
    jontymox
    I’ve replaced the diverter/valve assembly, and run the m/c.
    Unfortunately, the same problem remains.
    Wondering if it needs re-programming?
    jonty
    #425523
    have you wired that thing correctly? it is possible to get the 2 plugs in the wrong way around. was there a sign of leak from it? has been known for water to get on the microswitch and blow the module but its usually on the later types. Certain that is it the problem though.
    #425524
    jontymox
    Good morning,
    Wiring connection is fine, (keyed 4 way multi-plug) and no sign of water leakage.
    Inspected ecu visually, and it appears fine although could well be the underlying problem.
    Not sure whether to order a new ecu, as it’s v expensive and probably non-returnable, but customer wants problem fixing regardless… back to the drawing board.
    jonty
    #425525
    jontymox
    Good afternoon,
    Replaced electronic control module, and all well for around 30 minutes.
    Then, wash pump noisy/fails… so suspect this has damaged the original module.
    Kind regards,
    jonty
    #425526
    jontymox
    Renewed the wash pump/motor, and all well apart from water trickling through small lower condenser pipe onto base cover when drying.
    Does this suggest a blockage, as I’ve not come across this before?
    jonty
    #425527
    jeez, someone has spent a lot of money on this thing then…… Bet you wished you walked away from this one. how come the wash pump was alright for the first 3 minutes of running as per original post?
    The alt valve may well have a keyed 4 way socket but the 2 separate plugs can be fitted in the wrong positions, I know and I guess you will know how I know that.
    Never had the condenser leak other than the usual amount of condensed water which should not be an issue.
    #425528
    jontymox
    Hello again,
    Yes, I’m surprised that the customer has continued with the expensive repairs too.
    All fine now… the wash pump originally ran for around 30 minutes, before becoming noisy and breaking down… left to cool down, all well, until failing again after 20-30 minutes.
    I suspect the above has been the underlying fault, and damaged the ecu.
    Jon
