Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Smeg DI6012 failure
- This topic has 8 replies, 3 voices, and was last updated 12 years, 10 months ago by
iadom.
May 22, 2013 at 2:33 pm #75538
ModeratorNot been out to this yet, just spoken to customer on the phone
Apparently just over 12 months old, she had to call a Smeg agent out a few months ago for a similar fault.
At the time he told her that the pans or dishes she had put in where “too heavy”. 😕
She says there are lights flashing ‘aquastop failure’, I suspect a flooded base.
I know the old Smeg used to leak from the small, black rubber O rings on the fill chamber but wouldn’t expect that on a 12 month old machine.
Any help/advice welcome. 🙂
May 23, 2013 at 3:32 pm #395224iadom
ModeratorRe: Smeg DI6012 failure
Called this afternoon, as suspected the base had water in it.
Drained it out, removed both side panels and ran the machine for 15 minutes, no sign of a leak from anywhere. 😥
She said it was exactly the same when an engineer called out under warranty 4 or 5 months ago, he said something about “a one off” and also said the large metal roasting tray she had put in was “too heavy”… :con:
That sounds like a bit of bull to me, but I stand to be corrected. 8)
Anyone had any oversoaping issues with this fairly recent model?
May 23, 2013 at 4:27 pm #395225eastlmark
bottom spray arm split is the usual culprit. Too heavy is a load of nonsence. Sometimes get circ pumps leaking occasionally, very difficult to trace if so but if I get repeated failures like this and the spray arm has been changed, then I bung a pump in and dont usually hear from it again.
May 23, 2013 at 4:31 pm #395226iadom
I did wonder about the spray arm, even mentioned it to her as a common fault on Brandt and Indesit dishwashers. The fact that it is only just over 12 months old though led me to discount that. Will just have to monitor the situation for now. 🙂
Sent from my iPad using Tapatalk HDMay 23, 2013 at 4:50 pm #395227eastlmark
iadom wrote:I did wonder about the spray arm, even mentioned it to her as a common fault on Brandt and Indesit dishwashers. The fact that it is only just over 12 months old though led me to discount that. Will just have to monitor the situation for now. 🙂
its only the new ones that are faulty. replacement arm is strengthened.May 23, 2013 at 4:51 pm #395228iadom
Thanks Mark, I don’t suppose you have the part number handy by any chance. 😀
May 23, 2013 at 4:54 pm #395229Allsorts
ParticipantRe: Smeg DI6012 failure
I have had one where the rubber connector that connects the pump hose to the pump bulbed and started to leak… not on this model though.
George
May 23, 2013 at 7:07 pm #395230eastlmark
764570114
May 23, 2013 at 7:50 pm #395231iadom
:tup:
