SMEG DI612 PUMP FAULT
  • #51772
    Hi, can anyone help me out with a problem i have on this smeg dishwasher.
    on any programme you only get 110 volts down to the drain pump, howver if you put the machine into anti flood you get 240v and it runs.
    there is no break in the wireing loom and the pcb is ok, anyone any ideas please….
    Simon
    #309308
    Re: SMEG DI612 PUMP FAULT
    Float switch is a diect mains feed, the pump is otherwise switched by the pcb, so it’s probably not OK.
    Penguin45 wrote:Float switch is a diect mains feed, the pump is otherwise switched by the pcb, so it’s probably not OK.
    i fitted a new pcb as that is what i thought it was but it still done it. so im comfused
    #309310
    anyone?
    #309311
    you sure about those door loom wires?
