smeg di612 quits
  • #44886
    phil59
    hi everyone
    smeg di612 intregrated dishwasher fills and rinses 3 times then quits with the second light from the left flashing(glasses program) any ideas anyone
    thanks in advance phil
    #282806
    Re: smeg di612 quits
    sounds like an over-fill. this one can suffer a pcb failure that ignores the pressure switch sginal and continues to fill.
    #282807
    phil59
    cheers ill give a pressure switch a try
    #282808
    it wont be the pressure switch.
    #282809
    phil59
    its not the pressure switch 😉
    #282810
    DAR01
    Have you managed to resolve the fault on this one?
    I have a customer who has the same problem with a SMEG DI612C (does 3 rinses then faults out), the machine is about 2 years old, the overfill switch in the base has not operated.
    Mike
    #282811
    pup
    eastlmark wrote:sounds like an over-fill. this one can suffer a pcb failure that ignores the pressure switch sginal and continues to fill.
    #282812
    LJDomestics
    is this for guessing games and businessmen looking to hook up on scenario’s? its starting to look like this way of diagnosing ( lets post and see who’s had the same problems;s?)
    #282813
    Article HERE explains the basics, LJ. Substitution is often the only way ahead.
    This particular one is a dead cert module failure.
    phil59
    dont understand lj domestics post??
    #282815
    phil59 wrote:dont understand lj domestics post??
    you are not alone!
    #282816
    phil59
    good thought it was just me!!
