Smeg DI612C dishwasher.
  • #59152
    aqualectric
    Smeg DI612C dishwasher. 12053. 50202 1088 0.
    Smeg and intermittent faults…..aahhh….my favourite combination. 😈
    Start the cycle, fills, washes, heats, drains: then fills for the rinses and when full, pulses the motor and dispenser coil alternately. Coil pulse, motor pulse, beep from PCB. Does this forever.
    Swapped coil on dispenser – no difference. No earth problems found. So is it a PCB fault?
    Over to you…….thanks!!
    Steve.
    #337091
    aqualectric
    Re: Smeg DI612C dishwasher.
    Any help on this please?? 🙁
    Thanks,
    Steve.
    #337092
    as you said Steve, PCB if all else has failed.
    #337093
    M1
    Hi Steve
    I have a SMEG DW here if you need any spares to swap out !
