HI,
Saw the error on a Smeg and thought ah quick clean out and problem sorted; that’s what I thought when I received the call 🙂
Not so, this is a brand new, unused machine in a new installation. When a program is starts the drain pump runs for roughly a minute and the fill solenoid operates in about 5 second pulses. This then stops and the machine starts to fill. after a short time the first (rinse) light comes on which indicates an overfill error. The pressure hoses appear OK and the pressure switch situated at the front/right works. If I remove the hose to the anti flood devise, when the machine fills, water pours out after a short time which i assume is giving the error when connected.
Any ideas would be appreciated.
Thanks,
Keith.
