Smeg di612c strange fault (well to me)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg di612c strange fault (well to me)
  • #72941
    rub
    We have got a Smeg Di612c all it does when you switch on is beeb once and pulse the drain pump.Before you ask the light that flashes changes depending the programme set. It will flash THAT light twice, not the second from the left. I have checked all the usual ie supressor,solenoid,door switch etc no signs of faults anywhere and also no leaks. Would i be right in assuming its the board. doesnt get to fill or wash stage at all.
    Cheers
    Rub
    #386025
    rub
    Re: Smeg di612c strange fault (well to me)
    When i say We i mean in the workshop not mine personaly.
