Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Smeg DI612C Wont do anything really but pulse pump & va
- This topic has 6 replies, 2 voices, and was last updated 15 years, 7 months ago by
whiskeyjack6058.
September 12, 2010 at 11:44 am #57186
whiskeyjack6058
ParticipantSmeg DI612C
S/N 41011 0855 0Went out to this on Friday. You can set the program normally as you expect to. When you close the door, the dishwasher repeatedly pulses the drain pump and the water valve solenoid at the same time and doesnt do anything else really.
Customer told me they looked at the LED state and found the fault code – Temperature sensor via the instruction book.I ran an insulation test on the heater element and it was fine. Exposed the soap dispensor solenoid and got a reading through it.
Im guessing at the module which is a different module than the regular Smeg dishwasher. It’s also VERY expencive with a RRP of about £160 and a cost price of £114 + vat from connect and £137 inc vat from Smeg direct. Bit worried about this one. A company that I know have one in stock that was ordered for a job and never used and they have offered me it for £100 inc.
Dont know the way forward with this one. Just hoping someone on here may shed some light on it for me.
Hoping to hear soon.
Rob.September 13, 2010 at 8:35 am #330176electrofix
ModeratorRe: Smeg DI612C Wont do anything really but pulse pump &
check stick known pcb problems
sounds like capacitor on pcb faulty give a fault like low battery
cheap to fix so you have nothing to lose if your wrongDave
September 14, 2010 at 9:46 pm #330177whiskeyjack6058
ParticipantRe: Smeg DI612C Wont do anything really but pulse pump &
Hi Dave, Thanks for your advice. I removed the 1.5uf capacitor from the pcb, it’s rated at 275vac and changed it. The old cap that I removed – I charged it with a megger and shorted it. It gave out a pretty decent crack. I wouldnt have wanted it on my fingers put it that way. Would you think this suggests the caps not the problem?
Regards.
Rob.September 15, 2010 at 12:16 pm #330178electrofix
change it is the only way
cap is acting like a resistor to feed power to board
as it get older it feeds less to board might only be a 1uF now but would still give a crack on megger
September 15, 2010 at 12:59 pm #330179whiskeyjack6058
Ok, I have changed it now and the board is ready to go back onto the dishwasher. I will post the outcome of it.
Thanks once again.
Rob.September 15, 2010 at 4:42 pm #330180whiskeyjack6058
Well done Dave!! It worked!! I have one very happy customer who’s got the job done MUCH cheaper (like £150 cheaper) than I told him, and I havn’t had to pay out stupid money to buy a pcb while worrying if it was the real problem!
Im well happy!! Thanks again your a superstar!
Rob.September 15, 2010 at 5:40 pm #330181electrofix
no probs m8
glad it worked getting this problem on more and more on appliances so now you know it you can look out for it
