After 75 minutes of a 90 minute cycle, the dishwasher gives a beep similar to that you would get at the end of the full cycle. After a few seconds it gives a double beep, similar to the one that normally signals that an interrupted cycle is resuming. The spray arms start to rotate, stop immediately, and then a single beep again. This continues indefinitely.
The water inside is hot.
There are no fault codes shown.
On the face of it, the symptoms are similar to http://www.ukwhitegoods.co.uk/forumsphpbb3/viewtopic.php?f=33&t=23483 so I’m thinking I’ll replace the soap dispenser. However, I’m not sure which one to order.
Of these three http://shop.ukwhitegoods.co.uk/advanced_search_result.php?search_in_description=1&keywords=smeg+dispenser&x=0&y=0 the 00054 looks the same (except grey), but of course my exact model number isn’t listed :rolls:
The type number is 12053; Serial Number is 40915|0328|0
I’d be grateful if someone could give me some guidance on which dispenser I need (and if in fact I need one!)
Craig
