Smeg DI612CA built in dishwasher.
Programs start as normal with several fill/drain cycles.
Machine then fills, washes for about 3 mins and drains fills again washes for a further 3 mins and drains again.
Does this two more times then drains and bleeps showing F2 fault code.
Does not matter which program is selected.
Suspect the matrix on the side but machine is going to be a pig to extract and refit so would like to go armed with right parts
unlikey to be that as the pressure switch works of a seperate pipe to the sump. Check for blockage in the sump pressure chamber and that the pressure switch is ok. If so then its the pcb ignoring the signal. all of this can be done from the front without removing the appliance.
if you need a pcb let me know as I can do one for you. RRP is £140.44+vat by the way.
Many thanks.
Will go back for a further investigation.
Pig of a position, end of galley kitchen only just room to open door flat, have to load it from the side!
Have to take of end cupboard door and use mirror to read model number :rolls:
