Re: Smeg DI612CA dishwasher
Fitted an inlet valve on one of these on thursday and got same fault- reduced water pressure on tap and then worked OK
E2 – Safety pressostat intervention
This alarm is generated when the safety level (PRS1) intervenes, both when there is or there is not
the full tank signal (PL0). In this situation the programme is not immediately stopped, but however
the tank is emptied and then filled. The water quantity, in this case, is decreased.
This situation can happen max 3 times consecutively in a washing programme, after these 3 times
the programme stops signalling the anomaly.
This defect can be caused by:
– defective pressostat level
– difficulty to connect the pump or faulty washing pump
– water in the safety pressostat pipe
– filling solenoid valve with high flow rate
– electronic card which does not read the “full” signal
