I have been reading about this fault but am still a little confused about the result!!
Programs start as normal with several fill/drain cycles.
Machine then fills, washes for about 3 mins and drains fills again washes for a further 3 mins and drains again.
Does this two more times then drains and bleeps showing a light on position 2 & 5 then when the door is opened it shows lights on position 4 & 5.
Does not matter which program is selected. Seems like it could be high water pressure or a pcb fault….. so as its been working fine upto now and the customer hasn’t altered the tap, it must be the pcb — correct?
Can’t find any reliable error codes
Brett
