Smeg DI612CA failing to spray
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DI612CA failing to spray
Viewing 15 posts - 1 through 15 (of 15 total)
  • #88717
    rotis23
    Hi All,
    So I have my DI612CA that has been unused between 6 months and 1 year (don’t ask). It was full of skum and I had to literally carve the cheese/fungi/mould off of the nested filters (not nice).
    Anyway, after cleaning all internals thoroughly and attempting a couple runs I’m getting some weird problems.
    On a normal wash it seems to do an initial drain, fills with water and gets hot (actually very hot and seems to run out of water – I get 10 beeps at this stage of observation), and then eventually drains. It never seems to do any spraying. I just tried a short rinse cycle and it seems to do everything fine (fill and drain) but again, no spray.
    It looks like the drain pump is used to spray the water during the cycle – as draining is working fine I assume this is more likely a sensor issue. Could there be more scum affecting a float or other level sensor?
    My only other theory is that the spray arm is missing a seal and this is casing low pressure in the spray arm.
    Any help appreciated.
    Thanks, Chris
    #439139
    rotis23
    Re: Smeg DI612CA failing to spray
    OOops. Think I better check this first.
    http://www.ukwhitegoods.co.uk/help/fix- … her-error/
    I’m not getting E2 error but guessing it could be not filling fully.
    #439140
    Yep, if that fill chamber matrix is full of crud it’ll do weird stuff.
    rotis23
    Better/safer/easier to just replace the matrix?
    #439142
    If it’s gunked up that’s what I’d do, bluntly, life’s too short. 😉
    rotis23
    Thanks K.
    #439144
    If you mail Dave on spares@ukwhitegoods.co.uk he’ll advise what one it is if you need it and, probably get you a decent price on it.
    rotis23
    Already ordered from that link. Thanks for your help.
    #439146
    rotis23
    Fitted the fill chamber matrix and that hasn’t fixed the problem.
    The dish washer goes through this sequence:
    – drains and partly fills for a couple mins
    – drains
    – fills with water
    – sounds like its trying to heat (and on longer runs it does get hot)
    – then gurgles a lot as if trying to send pressure to the arms. No movement from arms.
    So looks like its still blocked somewhere. What is the best thing to check/clean next?
    Thanks again for help.
    Chris
    #439147
    Have you checked the record pump impeller housing?
    rotis23
    Re: Smeg DI612CA failng to spray
    Thanks for quick response K.
    Not yet – it is draining fine without any noise! Any instructions on checking the housing?
    #439149
    The record pump is the main wash motor, there’s also the drain pump.
    Not really any instructions as such, it’s really just a case of stripping out the underneath to get to them but, releasing the hoses should allow you to see or feel anything major in there causing issue.
    rotis23
    Got the circulation pump out and it seems clean – need to remove the housing to check. The hoses to the circulation pump seem clean too. How is the housing removed from the pump? It twists but unclear how much force I should use.
    If crud is not the problem in the circulation pump does that suggest the pump is gone or could something else still be blocking somewhere?
    #439151
    Andy jones
    Sounds like the pump has had it tbh
    #439152
    rotis23
    Thanks – everything points to that and the cost doesn’t justify the repair. Goodbye dishwasher.
