smeg DI612CA flood protection
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries smeg DI612CA flood protection
  • #32990
    monkey
    Hi Guys
    I hope you can help me with this dishwasher.
    It just out of guarantee,it is overfilling and going into flood protection. The pressure switch is connected directly to the side of the tank and I dont seem to able to get a part number for this, so I havent been able to try a pressure switch.
    monkey
    #237032
    Re: smeg DI612CA flood protection
    Monkey, if you had read your PM’s your would have known to send me your email address (as its not in your profile) and I would have sent you the service manual.
    Its not rocket science to blow up the pressure swtich while the dishwasher is filling to eliminate that.
    Have had one of these ignoring the pressure swtich signal, cure was a new module/pcb. Dont think that one has a flow meter but you may want to look in the side panel to find out.
    #237033
    monkey
    Thanks I have got drawing.When I called back and checked the pressure switch it as got a pipe coming out of it, I could not see it because it it comes out the top. I checked the pressure switch it seems to work ok.When you start the dishwasher everything seems to be working ok but it wont stop filling, you can hear the pressure switch click. I have checked the cables up to the module they are ok, all I can think of is the module must be faulty.
    I would appreciate any help.
