smeg DI612CA1 goes pop
Home Forums Public Support Forums Help And Support Dishwasher Help Forum smeg DI612CA1 goes pop
  • #72656
    zakado
    Hello
    I have a Smeg DI612CA1 when you close the door to start the cycle
    it starts up and 30 seconds later it blows the Fuse in the wall plate and trips the circut and leaves the aroma of burnt fuse
    any ideas
    thanks in advance
    George
    #385180
    Muv
    Re: smeg DI612CA1 goes pop
    You havent told us what appliance it is?
    Dishwasher? Washing machine.?
    #385181
    Muv
    Sorry, i should have looked at what forum it was posted in
    I would think its related to the heater, if its 30 seconds in to the programme
    M
    #385182
    deltra
    these are prone to interference filters shorting!!
    #385183
    zakado
    Thanks for the info
    so i have the heating element out and the block connector was fried so much so that its melted to the connection on the element i have it removed and have done a continuity test on the element and it seems to pass this is there any other reason why this would short out at the connector and i know i can buy the element but can i get a new connector to fit to the wiring
    again thanks in advance
    #385184
    zakado
    I think I have nailed it i removed the old connections and replaced the element fitted new connections and its working fine
    but why did it melt the original block connector i hear you ask on close inspection there where mouse droppings in the bottom tray and although hard to tell due to burnt wires you can see what looks like bite marks
    Mystery solved
    Thanks once again
    #385185
    repman
    any dead mouse?
    #385186
    zakado
    funny no i was disappointed about that it must have had a go when the machine was off and power only goes to the element 30 seconds after cycle starts maybe next time lol
