smeg dishwasher
  • This topic has 5 replies, 4 voices, and was last updated 20 years ago by jd.
  • #16799
    jd
    smeg dishwasher dwi 710e, this machine has five programme lights fault is number 2 & 4 lit 5 flashing constantly unable to cancel by holding p button in heater ok pump etc checks ok has board crashed
    thanks jd
    #171628
    Re: smeg dishwasher
    have a look in the ‘Known error codes ‘ thread at the top of this forum, a few Smegging, Smeg bits and pieces in there for starters. 🙂
    #171629
    Dave_Conway
    Re: smeg dishwasher
    Hi jd and welcome 🙂
    For future reference you can find many of the known error codes at the top of this forum including the Smeg ones.
    This is a typical unlisted one and will nearly always be the dispenser solenoid s/c or o/c causing mayhem with the PCB 😉
    #171630
    Dave_Conway
    Re: smeg dishwasher
    :wave:
    #171631
    jd
    Re: smeg dishwasher
    while browsing i found the error codes you mention will try the dispenser solenoid as you suggest.
    many thanks john.
    #171632
    clivejameson
    Re: smeg dishwasher
    Incidentally, I have had a couple of these faulty dispenser solenoids only show up when you gently flex the contacts on them and watch the circuit disappear on your meter. 😉
