my dishwasher suddenly started to leak under the door,i replaced all the seals iedoor seal the goalpost and L shaped seals but it still leaks.can anyone help.
Damage to the lower rotor can cause this, flow restriction to top rotor can force too much water through the bottom rotor as well. Check that the latch loop for door hasn’t slipped forward, allowing the machine to operate with the door not quite closed fully.
