Smeg Dishwasher DI612C Disp Coil or PCB?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg Dishwasher DI612C Disp Coil or PCB?
  • #44473
    laurenceuk
    This saga continues.
    I was able to get the fault to occur by getting a book to read and waiting for
    the machine to go through the program.
    It stopped after the final rinse had got to temperature and then it began
    to pulsate. A beep would occur then a couple of seconds rest then the
    dispenser solenoid would cycle and the recirc motor start for a second or
    two with another beep – simultaneously.
    The relay or relays in the programmer can also be heard to cycle.
    This pulsing cycle would then continue indefinitely until the program was
    canceled.
    What is causing this? A faulty solenoid coil in the dispenser or a faulty
    programmer.
    I did try an ordinary washing machine valve in circuit but this made no
    difference. The dispenser solenoid coil is about a quarter of the
    resistance of the water valve coil.
    Laurence
    #281086
    Re: Smeg Dishwasher DI612C Disp Coil or PCB?
    PCB, Laurence. You have had a peek at the suppressor as well?
    laurenceuk
    Thanks Penguin,
    I feared as much.
    Yes I did look at the externals of the supressor and it looked intact.
    Would this have an effect so far into the prog if faulty!
    Funny enough I changed the supressor on its mate in the holiday let next
    door about a year ago, that kept blowing the trip.
    Thanks again
    Laurence
