Smeg Dishwasher DI612C Sticks in Prog
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg Dishwasher DI612C Sticks in Prog
  • #44403
    laurenceuk
    This machine will fill and heat but eventually you will hear a pulsating noise
    as if the motor starts for a second or two and tries to pump the water
    through the spray arms then stops and repeats this over and over.
    I`m pretty sure it is this motor and not the drain motor.
    Any insights would be appreciated.
    Laurence
    #280877
    Re: Smeg Dishwasher DI612C Sticks in Prog
    dispenser coil maybe? worth a shot.
    #280878
    laurenceuk
    Thanks Mark,
    Would a faulty coil cause the motor to pulsate, the dispenser opened fine.
    The problem occurs later in the program.
    Incidentally it went through a `rinse only` program ok.
    Thanks for again for your response.
    Laurence
    #280879
    dont know for sure but woth connecting a valve coil up just to prove it. The pulsating is a classic dispenser coil symptom.
