Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Smeg Dishwasher DWD612CSS Panel
- This topic has 6 replies, 2 voices, and was last updated 6 years, 1 month ago by
Allan12.
February 22, 2020 at 2:27 pm #97241
Allan12
ParticipantWhen I press the power button the power light briefly lights and then fades. I cannot start any washing programmes. Any ideas of what is wrong please?
February 22, 2020 at 8:31 pm #466639kwatt
Keymaster|Have checked the supply is okay?
After that, mains filter then mins switch, then you get into the more difficult stuff.
February 22, 2020 at 9:08 pm #466640Allan12
ParticipantHi Kwatt
I know the power supply is fine because I can hear the solenoid is working. The dishwasher is near to our main water supply inlet and causes a small bit of water hammer. Sorry for the stupid question but how do I check the mains filter and mains switch without replacing them?
February 22, 2020 at 11:47 pm #466641kwatt
KeymasterThe mains switch is usually reasonably simple as that’s just a make/break switch effectively for more, the format varies but the same idea on all.
It’s this: https://shop.ukwhitegoods.co.uk/816450164-smeg-dishwasher-power-switch
Simply metering it will test if it’s okay. All it does is make or break.
The mains filter is really a capacitor in disguise and if they got there usually evidently failed but I do think that’s a long shot here. That said, it’s not an uncommon thing to fail, this kind part is what you’re looking for but the format can vary:
https://shop.ukwhitegoods.co.uk/813410489-mains-interference-filter
Or : https://shop.ukwhitegoods.co.uk/813410094-smeg-dishwasher-mains-suppressor
Door switch, maybe.
But from what you’re saying, if it’s trying to fill and not, the valve needs checking as well.
After that though your into checking the recric pump, boards and stuff so it gets a lot harder.
February 23, 2020 at 3:53 pm #466642Allan12
ParticipantHi Kwatt
Thanks for the info. I haven’t got a test meter, but power must be getting through otherwise I wouldn’t hear the solenoid. It isn’t trying to fill, I’m not getting that far. I’m assuming it must be a problem with control panel, otherwise I would be getting a series of power lights showing an error code. I press the power switch, hear the solenoid move and then nothing.
Regards
Allan
February 23, 2020 at 5:11 pm #466643kwatt
KeymasterPossibly but that’s not an easy machine for beginners as it’s’ got three boards in it if memory serves.
But it should clear the sump first so, are you hearing the pump running or a valve? After it clears the sump then it’ll fill. Then it’ll start to wash and heat.
The trick is working out what bit of that it’s not doing.
February 23, 2020 at 9:47 pm #466644Allan12
ParticipantHi Kwatt
Thanks for all your help, it’s a bit complicated for me and I haven’t got the equipment, so I’ll get an engineer to have a look at it.
Allan
