Smeg Dishwasher DWD64SSE
  • #21838
    roly16
    Does anybody know if there’s an MFI model the same as this so I can look it up on MFIdent? If not, does anyone know what fault code the first & third neons from the lhs lit up indicate? When you start a progaramme you can hear the timer/slave unit [whichever it is] indexing round to the start position but nothing happens. Assume it should pump out first but there are 2 lives to the pump. [The pump runs ok if you activate the anti-flood float switch.]
    Any help or service info greatly appreciated.
    Geoff
    #192699
    Re: Smeg Dishwasher DWD64SSE
    No mfi model that complex I am affraid, but it is the alternating valve you can hear wirring, this has a microswitch on it that often fails. best take the thing off, (it just pushes into the sump) and test it. just four wires, 2 are the motor you can connect to 240v while the other 2 are the switch contacts should be normally open, (I think) and then closes for a second or so.
    #192700
    roly16
    Thanks Mark,
    Would failure of this microswitch prevent the machine from draining/filling at the start of a programme?
    #192701
    It does a self test before starting anything, so it is possible. on machines with a display it shows F8 and shuts down right at the start. on that model you have, the error codes are not clear so I cannot tell you what your flashing lights mean. Check also the dispenser coil. If all are ok suspect the pcb board itself. The alternating valve seems a common failure at the moment so i would start there as its so easy to test.
