Smeg dishwasher DWI612 leak at water softener
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg dishwasher DWI612 leak at water softener
  • #35600
    ascanlon
    I have a leak where the pipes which lead from the water softener control on the inside of the dishwasher join the water softener. It looks like an O ring washer will cure it. However I need to either free this assembly or the water softener assembly so that the pipes and the water softener can be separated. Does anyone know if the plastic ring around the water softener control can be unscrewed or popped out. I’ve tried unscrewing it but it won’t budge.
    thanks
    Andrew
    #247263
    Re: Smeg dishwasher DWI612 leak at water softener
    It should unscrew……..
    ascanlon
    Great ! Thanks for your help. I managed to get the plastic ring unscrewed and as I suspected an O ring solved the problem. All done for 99p!!
