Smeg Dishwasher DWI612C
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg Dishwasher DWI612C
  • #29417
    darren9
    Can anyone help? The last two dishwasher lights are stuck on red (so if you are looking at the dishwasher they are on the right hand side) and we can’t change them. Can’t switch the dishwasher on or off its completely stuck and these two lights are on red permanently.
    #223042
    clivejameson
    Re: Smeg Dishwasher DWI612C
    If they won’t even go off when you switch off…try switching off at the wall/supply switch and restoring power again.
    It’s possible that the pcb has let go, and if it has there’s also a possibility that another component has failed and damaged the pcb 😕
    If you need an engineer then try the link below?
    #223043
    darren9
    Thanks for the response. The pcb, that sounds serious (and expensive), is it? Is it anything I can attempt to repair. The user manual I have isn’t that helpful. Tried switching on and off at the wall, no luck.
    #223044
    clivejameson
    Almost certainly the pcb then i’m afraid 😕
    Not sure of the price TBH but wouldn’t be surprised if it’s closer to £200 than £100 so might be worth getting a professional in to check the rest for you and give you an estimate before you splash out on the off-chance?
    #223045
    darren9
    Thanks! I’m off for a lie down … 😥
    #223046
    clivejameson
    One final thing you could try is the reset procedure which IIRC is to switch on the power button and press the program button four times within 3 seconds but i have to say i’m not hopeful sorry 😕
    Incidentally an email to spares@ukwhitegoods.co.uk will get you an accurate price.
