Smeg dishwasher E1 fault
  • #41190
    geoffmackay
    Smeg 101045 UKSTX 1-1 103063 dishwasher. Fitted a mouse eaten drain hose today. Now on second wash customer is repoting E1 error. Any ideas chaps?
    Geoff
    #269086
    pen0668
    Re: Smeg dishwasher E1 fault
    hi im sure e1 on that machine is anti flood device activated (mouse poss eaten anouther pipe??)
    hope that helps darren
    #269087
    water in the tray, you did dry it out I assume? if so then I am affarid you have a leak…or the mouse has feasted on the polystyrene float!
    #269088
    From the Known Error Codes thread. 😉
    E1 – 1st flashing, 5th lit – flood protection system activated.
    E2 – 2nd flashing, 5th lit – safety pressure switch activated.
    E3 – 1st, 2nd flashing, 5th lit – no heat in time allowed.
    E4 – 3rd flashing, 5th lit – temperature sensor fault.
    E5 – 1st, 3rd flashing, 5th lit – no fill.
    E6 – 2nd, 3rd flashing, 5th lit – no drain in time allowed.
    E7 – 1st, 2nd, 3rd flashing – flow meter detected when not fitted – reset required.
    E9 – same code as E1, so how you tell the difference is beyond me, but is a related fault to E1 + E2.
    I had an Indesit dishwasher with same fault yesterday, the plastic drain hose was completely chewed in half, the culprit was lying dead under the machine when I tipped it up. It must have swallowed a load of the plastic or something.
    geoffmackay
    Thought it could be that, thanks to all.
    Geoff
    #269090
    Simon46
    Yes i suspect polystyrene balls jammed under polystyrene float. vacumn out.
    S.
