Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › smeg dishwasher error e1, I like washing up anyway
- This topic has 5 replies, 2 voices, and was last updated 19 years, 11 months ago by
slipper.
May 6, 2006 at 12:02 pm #17627
slipper
Participantsmeg dishwasher model dw17 10E1 shows error code E1 “the dishwasher’s anti-flooding system has been activated (only for models equipped with the TOTAL AQUASTOP device)”
But there isn’t a leak, and I am not convined that this quite ordinary model has total aquastop.
Does anyone have a clue?
May 6, 2006 at 12:22 pm #175527Penguin45
ParticipantRe: smeg dishwasher error e1, I like washing up anyway
Has it got a box on the fill hose at the tap end? If so, you have an aquastop hose.
Penguin45.May 6, 2006 at 7:19 pm #175528slipper
thanks, penguin. No such box – so I wonder why this error message. Certainly the machine won’t allow any water in, and maybe a fauty inlet valve solenoid would prompt the same error code. Also the pump keeps running for ever, but maybe this too is about the error code.
May 6, 2006 at 8:15 pm #175529Penguin45
You say that the machine is not leaking – you have checked the undertray for water? There is a float/diaphragm mechanism in the base, which can be triggered by water lying in the tray OR by the fill matrix sludging up and diverting water to the cut-off circuit. This is a technically complex machine and extensive dismantling is required to fully diagnose the problem.
Probably time for professional help? Click the link below for a repairer in your area. Power off if you are going to investigate further.
As an aside, I attended one of these recently to find that the float mechanism was activated by the body of a late mouse………
Penguin45.May 9, 2006 at 9:25 am #175530slipper
thank you, I’ll have a look.
May 20, 2006 at 6:23 pm #175531slipper
Here is the answer that I found, and thanks very much for your help.
I took the front bottom panel off and found that the float switch which presumably controls the drain pump was quite flooded although not enough for any water to drip on the floor. so I dried it with a bit of kitchen roll and the machine was fine.
This must have been causing the leak error code and stopping the inlet valve from working, and causing the pump to run continuously. No idea what the cause was or whether it will return, but the machine has worked fine for 2 weeks now.
very good forum.
