Smeg Dishwasher help with fault finding Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Smeg Dishwasher help with fault finding This topic has 3 replies, 2 voices, and was last updated 3 years, 10 months ago by eightpans. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts May 24, 2022 at 5:36 am #100839 eightpansParticipant Hi Smeg ST2FABRO2 SI 01 S/N 50521 0033 1 Full S/N 1 139186 50521 0033 03 00 Fault – Does not heat water – It runs through it’s cycles in all other respects just with no heat… In order of probability what would be the problem here ? Regards Chris May 24, 2022 at 8:36 am #482368 electrofixModerator the heater element is always the first thing to check Dave May 24, 2022 at 2:27 pm #482369 eightpansParticipant Hi Dave Many thanks for the reply… Seems OK on the meter…What would the next thing to check be ? Chris May 24, 2022 at 7:19 pm #482370 electrofixModerator there is not a lot of tech info for smeg but check wires from heater to board check wires from temp sensor to board check heater relay on board for bad solder joints Dave Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
