Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › SMEG DISHWASHER Mod. DWF 66?
- This topic has 9 replies, 4 voices, and was last updated 20 years, 3 months ago by
Ashby.
January 11, 2006 at 5:57 pm #14724
Ashby
ParticipantHi, anyone familiar with Smeg? I’ve never worked on one before.
The customer tells me it takes about 3 hours to complete a program, doesn’t always drain, only on certain programs. Has anyone got info on this machine? I’m going to have a look next Wednesday.
Much obliged for any help.
AshbyJanuary 12, 2006 at 6:27 pm #160602eastlmark
ModeratorRe: SMEG DISHWASHER Mod. DWF 66?
Probably just blocked, the pump is right at the front under the door and can be accessed without even pulling the machine out. Usually get error codes or flashing lights to indicate problem. See the error codes thread here.
January 13, 2006 at 8:42 am #160603Ashby
ParticipantRe: SMEG DISHWASHER Mod. DWF 66?
Hi, thanks for your help with this one. I did ask customer if an error code came up. but she said E8 came up for a while but now has cleared. will see when i go Wednesday. Thanks for your help.
AshbyJanuary 19, 2006 at 9:07 am #160604Ashby
Hi, Going to have a look at this machine on Sat. Customer says it stops and starts throughout the cycle and drains on a rinse cycle? This’ll be the first smeg i’ve dealt with.Any help will be most grateful. (no error codes showing)
Many thanks.
Ashby.January 19, 2006 at 9:45 am #160605NWAR
E8- This alarm is generated when, at the programme start, the timer card does not detect the signal coming from the alternate valve positioning.
this defect can be caused by :
-faulty alternate valve
-electric connections not properly carried out
-defective electronic cardHTH
January 19, 2006 at 9:47 am #160606NWAR
Might just be needing a reset though. Do a search for “Smeg AND reset” or “Diplomat and reset” if you need information on how to do this; it’s been posted many times before.
January 21, 2006 at 8:14 pm #160607Ashby
Hi, Would someone kindly tell me how to Reset this machine please. Many thanks.
AshbyJanuary 21, 2006 at 9:17 pm #160608NWAR
January 27, 2006 at 6:54 pm #160609Ashby
Hi, I’ve had a look at this dishwasher, Tested the dispenser coil and that is ok, tried reseting it without success. whatever program you set it on it will start for about a min or so then it will cut out the display goes off too only for a few seconds then comes back into life for a further few seconds and goes off again. And this is how it goes. I’ve done what P45 has suggested without success. The PCB looks ok too.
HELP! Many thanks.
AshbyFebruary 6, 2006 at 8:27 pm #160610AASWALES
try looking at the outlet hose where it connects to the trap , cud be blocked
