Smeg Dishwasher not emptying at end of cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg Dishwasher not emptying at end of cycle
  • #45870
    alanthomas30
    Our Smeg diswasher is not pumping out water at the end of each cycle. If you empty it manually it will run through the next cycle but stop again without pumping out the water.
    Any ideas for fixes gratefully received
    #287479
    Re: Smeg Dishwasher not emptying at end of cycle
    Drain pump/sink coupling blockage, failed drain pump.
    Model number please if you need more specific information.
    clivejameson
    Dismantling of the drain pump to remove whatever is blocking it is your course of action 😉
