Hi Folks.
I am hoping that there is someone out there with some previous dealings with this model.
The problem is simple, the main oven fan/element not working because the l/h door spring is broken and the hinge arm is not operating the changeover microswitch. However due to the pig of a position this oven is in it looks like a two man job to remove the oven from carcass and remove side panel. My query is.. if this is a stock fault do I need to order any parts to the microswitch assembly or will just hinges do the job…or have I got to bite the bullet and drag it out to have a look?.
Anyone got an exploded parts diagram for this model?.
Any Assistance as usual much appreciated.
Mike
