smeg do10pss
  • #99306
    eng14
    hi all seems this one is a common fault on these,top oven ok.main oven runs to about 200c then clock goes blank and fan stops.reset clock and it goes again.pulled it out and watched lower fan that slowed to a stop then restarted.have put new cut out on it.?
    #475797
    Lawrence
    it needs 806890480 cooling fan resistor
    #475798
    kaibart
    Totally agree common to fail
    #475799
    eng14
    thanks guys
    #475800
    eng14
    hi guys changed resistors today cooling fan stays on now but still clock goes off around 200c,richard
    #475801
    Lawrence
    818730566 is the safety stat , have you tried temp testing at a lower temp to verify the stat is working ? Or is it going to max and knocking out the safety stat and then cooling down
