Smeg door open fault
  • #93940
    acland
    I have a Smeg WDI14C7 washer dryer which won’t start and falsely displays ‘open’ on the display. I have changed the door lock and checked the wiring to the control module. Is it safe to assume the fault is probably the control module?
    I guess it’s impossible to get a schematic of the control module (I am an electronics engineer and have some chance of locating the fault). I don’t think £200 for a new module is justified so unless anyone has any good ideas I will just break it up for parts.
    #455958
    acland
    Re: Smeg door open fault
    I spent quite a few hours trying to diagnose the fault without a schematic. The fault was eventually traced to an open circuit via hole on the control panel pcb (the drive to RL7 coil from driver IC).
    I feel that manufacturers like Smeg don’t want us to repair things so they don’t supply schematics and they elevate the price of spare parts in order to encourage people to buy something new when something goes wrong. A few years ago I designed TV’s and I recall a service manual was made available which provided schematics, circuit descriptions and diagnostic information (voltages, signals present etc). I feel we haven’t progressed very much and tend to ignore the environmental consequences of a throw away society.
    #455959
    so I take it you mean one of the holes that connects the print on one side of the board to the other
    if that’s true that’s bad manufacturing as that should never happen
    well done finding that
    acland
    Yes a via is a plated through hole which conducts from one side of the PCB to the other. Whilst you say it shouldn’t happen I am concerned that when the door lock relay is switched off there is an inductive back emf which causes a pulse of current that flows through the protection diodes in the device. Some relays have a built in protection diode but in this case the current flows back to the driver IC hence the PCB track has to handle a short pulse of a higher current than normal. To me it looked like the via and associated track had blown and there was a slight green smudge on the switch that sat above the via. There might be a slight design weakness in terms of the track width and the size of via, but maybe it was just poor plating in the via hole which fused. One final thought is that if a PCB track driving a relay goes open circuit when the relay is turned on the back emf in the absence of a protection diode will be significant which could cause the sort of fusing I noted as the high votage causes a small arc across the break which would account for the green smudge I noticed above it.
