Re: Smeg DRY72BK front drum seal fitting
Well fitted customer bought seal as I thought it would fit on front. Oiled it with lubricating oil as per badly photostatted Italian instructions. Sounds good on rotation but now No heat. Back panel removed found tripped resettable toc. Reset toc tested with no load all good I thought. Cust now rings up dryer says water tank full light is on after 3 minutes But no water in tank. Lift pump isnt operating maybe. dryer has been tipped on its back so maybe microswitch has got wet. This has had 3 1/2 hours labour on it.
