Smeg washer dryer model no wdi126c.Fault is dryer wont heat.Re set cut out switch and dryer started heating. Tried again a few minutes later and machine failed to start and shows a F-13 fault. Can clear this by disconnecting a lead from the cut out (dryer wont heat again but machine starts normally again)Re-connecting this lead causes F-13 fault to return and m/c again refuses to start.
Any help on this will be appreciated.
