Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Smeg dual fuel oven SPA 42016?? Natural gas jet conversion
- This topic has 6 replies, 4 voices, and was last updated 15 years, 1 month ago by
Andystu.
March 5, 2011 at 8:53 pm #61483
Andystu
ParticipantHi guys, I have a friend who has obtained a Smeg Oven, Gas Hob and electric oven 70cm. The model numbers he has txt me from the rear of the machine are A42 or SPA 42016. Could anyone tell me if these numbers look right?
Also, the reason we need the model numbers is, it is currently converted to LPG. Could anyone tell me what I will need to order for the gas fitter to convert it back to Natural gas as the previous owner has lost the originals.Many Thanks for your help as always..! :rolls:
March 5, 2011 at 9:39 pm #346344eastlmark
ModeratorRe: Smeg dual fuel oven SPA 42016?? Natural gas jet conversi
A42 is the model, all I have is a parts manual but would not know which parts you need.
March 5, 2011 at 9:53 pm #346345Andystu
ParticipantRe: Smeg dual fuel oven SPA 42016?? Natural gas jet conversi
Thanks for the confirmation of the model. Atleast I now know what model it is if I need to contact Smeg. The parts info in the parts manual may be useful at some stage. Thanks again
Andy Stu
March 6, 2011 at 7:19 am #346346wards
you will need to replace the burner jets and alter the airation as per mi,s,,the cooker hose should have a red stripe running down it and i would recommend you change the hose aswell.HTH
March 6, 2011 at 7:45 am #346347wards
doh,just re read the topic Natural gas jet conversi. 😳
March 7, 2011 at 10:11 am #346348Andystu
Hi. Thanks for your reply..! Apologies, I didnt quite understand the 2nd reply!! I presume we will need to order Natural Gas jets and replace the gas hose and have the airation altered? I dont suppose you would have the part numbers for the jets.
Many thanks
Andy Stu
March 9, 2011 at 3:59 pm #346349mdeang
if you follow this link the kit should be available
